AOC Pro-line U2777PQU 27" 3840x2160 4ms HDMI(MHL) VGA DVI-D DisplayPort 4K LCD Monitor
Quicklinx: D6WMWS00 Mfr#: U2777Pqu
Featuring advanced IPS panel technology, Ultra HD resolution and a frameless screen in 16:9 format, this display is designed to impress demanding professionals. The monitor comes equipped with a variety of display connectors and an ergonomic stand for enhanced convenience and productivity.
  • 4K UHD resolution
    Ultra high definition 3840 x 2160 resolution (4K UHD) yields a superior pixel density of 157 PPI (pixels per inch) on the large 27-inch screen, for outstandingly detailed images. The 10-bit Deep Color RGB display panel ensures substantially more natural transitions between hues for exceptional realism.
  • Height Adjustable Stand
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
  • Wide Colour Gamut
    When you are enjoying photos, videos or games, we want your screen content to look as lifelike as possible. That is why this display comes with Wide Colour Gamut technology, which means that it is able to display a lot more colours than conventional monitors. This is achieved through a special hardware solution, not through mere software adjustments. The result: true-to-life images with fine details that become visible thanks to the broader colour palette.
  • IPS Panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
AOC Pro-line U2777PQU - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Colour Support
1.07 billion colours
Input Connectors
HDMI (MHL), VGA, DVI-D, DisplayPort
Display Position Adjustments
Black, silver
53.115 cm x 22.4 cm x 48 cm
7.3 kg
Environmental Standards
TCO Certified Displays 8
3-year warranty
Display Type
Energy Class
Class C
64 kWh
44 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Flicker Free technology
Black, silver
53.115 cm x 22.4 cm x 48 cm - with stand
7.3 kg
Audio
Speakers
Output Power / Channel
3 Watt
DVI-D , HDMI , VGA , DisplayPort , MHL
Mechanical
Tilt Angle
-5/+24
Swivel Angle
330
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable , 1 x display cable , 1 x audio cable , 1 x SuperSpeed USB cable , 1 x power cable
Security Slot Type
Kensington security slot
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
TCO Certified
Limited warranty - 3 years
