AOC Pro-line I2790VQ 27" 1920x1080 4ms  HDMI, VGA, DisplayPort LED Monitor
Quicklinx: D6WHWS00 Mfr#: i2790VQ/BT
The AOC I2790VQ brings an appealing design and functionality together for business users and prosumers. Its IPS panel produces crisp, vivid imagery in high resolution, while offering viewing angles of up to 178°. Its HDMI, VGA and DisplayPort inputs offer a variety of connection options. Users spending long hours in front of a monitor will be relieved with the Flicker-Free technology reducing flicker by regulating backlight with a DC system, and the Low Blue Light mode reducing the harmful short wavelength blue light.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Flicker Free
    AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
  • IPS Panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen.
  • Frameless Design
    3-Sides frameless design of the monitor lets the user focus on the vivid display, and onlookers will enjoy the sleek and modern look from every angle.
  • Wide Colour Gamut
    When you are enjoying photos, videos or games, we want your screen content to look as lifelike as possible. That is why this display comes with Wide Colour Gamut technology, which means that it is able to display a lot more colours than conventional monitors. This is achieved through a special hardware solution, not through mere software adjustments. The result: true-to-life images with fine details that become visible thanks to the broader colour palette.
AOC Pro-line I2790VQ - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Power Consumption (On mode)
18.8 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Gamut
100% sRGB, 90% NTSC (CIE 1976)
Input Connectors
Display Position Adjustments
Tilt
Voltage
AC 100 - 240 V (50/60 Hz)
Grey
61.26 cm x 19.97 cm x 45.23 cm
4.7 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, FCC, RoHS, DICOM Part 14, REACH, TUV Bauart, EuP, EAC
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, Eco-Mode, Low Blue Light Mode, Flicker Free technology
Grey
61.26 cm x 19.97 cm x 45.23 cm - with stand
4.7 kg
Audio
Speakers
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort
Mechanical
Tilt
Tilt Angle
-3.5/+19.5
VESA Mounting Interface
100 x 100 mm
VESA interface support, PVC free
1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m
Input Voltage
18.8 W
18.8 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
