AOC Pro-line I2775PQU 27" 1920x1080 4ms HDMI DVI-D VGA DisplayPort LED Monitor
Quicklinx: D6WCWS00 Mfr#: I2775PQU
This IPS monitor offers a broad range of connectivity options including DisplayPort and HDMI as well as speakers and ergonomic adjustment.
  • Integrated speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Height adjustable stand
    Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
AOC Pro-line I2775PQU - LCD monitor - Full HD (1080p) - 27"
LCD monitor - 27"
Energy Class
Class A
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Plug and Play
3-year warranty
Display Type
LCD monitor
Energy Class
Class A
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
I-Menu, e-Saver technology, Zero power switch
Audio
Speakers
VGA (HD-15) , HDMI , DisplayPort , Headphones , DVI
Mechanical
VESA interface support
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable
Plug and Play
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Limited warranty - 3 years
