AOC Pro-line I2275PWQU 21.5" 1920x1080 4ms HDMI DVI-D VGA DisplayPort LED Monitor
Quicklinx: D6W7WS00 Mfr#: i2275PWQU
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£112.49 ex VAT
£134.98 inc VAT
This versatile 21.5-inch IPS display offers excellent performance for any task. Full HD resolution, high contrast ratios and wide viewing angles produce sharp, vivid imagery. A wide range of connectors, including DisplayPort, DVI, HDMI and USB (2.0 and 3.0) make it easy to hook up your computer and other devices.
AOC Pro-line I2275PWQU - LCD monitor - Full HD (1080p) - 21.5"
LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
50.4 cm x 21.29 cm x 46.88 cm
4.97 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
3-year warranty
Display Type
LCD monitor
Energy Class
Class A
26 kWh
18 W
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
HDCP, i-Menu, e-Saver technology
50.4 cm x 21.29 cm x 46.88 cm - with stand
4.97 kg
Audio
Speakers
Output Power / Channel
2 Watt
DVI-D , HDMI , VGA , DisplayPort , Audio line-in , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+20
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x USB 3.1 cable , 1 x audio cable , 1 x DisplayPort cable
14 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
ENERGY STAR Certified
Limited warranty - 3 years
AOC Pro-line I2275PWQU 21.5 Bundle deal on AOC Pro-line I2275PWQU 21.5" 1920x1080 4ms HDMI DVI-D VGA DisplayPort LED Monitor
£211.66
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
