AOC Pro-line E2275SWJ 21.5" 1920x1080 2ms HDMI DVI VGA LED Monitor
Quicklinx: D6W5WS00 Mfr#: E2275SWJ
This versatile 21.5-inch display provides excellent picture quality and performance in any department. Full HD resolution, high contrast ratios and fast response times produce sharp, vivid imagery. Flicker Free technology enhances your viewing comfort.
  • Comfortable viewing, remarkable performance
    This model targets business and home office users alike. Hidden behind its classically designed case is the latest LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. The environmentally friendly display comes in an elegant, textured black finish.
  • Vesa mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3rd party mounts and stands thanks to the VESA mount option.
  • Full HD resolution
    Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources.
  • Integrated speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
AOC E2275SWJ - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 200000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Voltage
50.4 cm x 19.35 cm x 39.54 cm
3.15 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
3-year warranty
Display Type
Energy Class
Class A
31 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
WLED
HDCP, i-Menu, e-Saver technology, Flicker Free technology
50.4 cm x 19.35 cm x 39.54 cm - with stand
3.15 kg
Audio
Speakers
Output Power / Channel
2 Watt
DVI , HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Stand
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Security Slot Type
Kensington security slot
Input Voltage
21 W
Power Consumption (Typical)
17.1 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption (Off Mode)
0.2 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
