This high-performance office display combines convenience with superior picture quality. With optimized brightness and high contrast ratios, the 21.5-inch E2275PWQU delivers sharp, vivid imagery in Full HD (1920 x 1080) resolution. Fast 2ms response time handles videos, animations and the most demanding software applications with ease. Integrated VGA, DVI and HDMI connectors plus USB 2.0 and 3.0 ports make it easy to connect a computer, laptop and a range of other devices. The built-in speakers and headphone jack offer extra convenience for online calls and more. To keep you working in comfort, Flicker Free technology helps reduce eye fatigue.
Height adjustable stand
We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing. -
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Display Port
The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications. -
USB Hub
Built-in USB hubs in AOC's monitors bring ease of use and practicality to your desk. Side mounted ports are easily reachable without even looking at them; negating time wasted searching the backside of a PC case to find a free USB port.
- AOC Pro-line E2275PWQU - LCD monitor - Full HD (1080p) - 21.5"
- LCD monitor - 21.5"
- Energy Class
- Class A
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, DisplayPort, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.4 cm x 46.88 cm x 21.29 cm
- 4.97 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Energy Class
- Class A
- Diagonal Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- HDCP, i-Menu, e-Saver technology, Flicker Free technology
- Black
- 50.4 cm x 46.88 cm x 21.29 cm - with stand
- 4.97 kg
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- DVI , HDMI , VGA , 4 x USB 3.0 , Audio line-in
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 330
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x SuperSpeed USB cable , 1 x audio cable , 1 x DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- On / Off Switch
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
