AOC Pro-line M2060PWQ 19.5" 1920 x 1080 5ms VGA, DisplayPort LED Monitor
CLEARANCE!
Clearance
Quicklinx: CC67WS00 Mfr#: M2060PWQ
The AOC Pro-Line M2060PWQ offers energy-saving LED backlight, Full HD resolution and high contrast ratios which delivers clear, vibrant images at your home or office. Features like height adjustable stand and Eco mode & E-saver improve ergonomics and further reduce power consumption.
AOC Pro-line M2060PWQ - LED monitor - Full HD (1080p) - 19.53"
LED-backlit LCD monitor - 19.53"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.22 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Voltage
47.76 cm x 17.95 cm x 35.83 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, RoHS, TUV Bauart
3-year warranty
Display Type
Diagonal Size
19.53"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.22 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, i-Menu, e-Saver technology
47.76 cm x 17.95 cm x 35.83 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort
Mechanical
Tilt Angle
-5/+22
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable
Input Voltage
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
CC67 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £12.92
