AOC I960SRDA 19" 1280x1024 6ms DVI HDMI DP IPS Monitor
Quicklinx: B8NKWS00 Mfr#: I960SRDA
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 14ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
15 in stock
£101.56 ex VAT
£121.87 inc VAT
This model targets business and home office users alike. Hidden behind its classically designed case is the advanced LED technology. It boasts a high typical contrast, ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel’s brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured finish.
AOC Pro-line I960SRDA - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
40.92 cm x 21 cm x 40.51 cm
2.85 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
3-year warranty
Display Type
Diagonal Size
19"
Viewable Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
140 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Screen+, i-Care
40.92 cm x 21 cm x 40.51 cm - with stand
2.85 kg
Audio
Speakers
DVI , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Wall mount
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Power Supply
Internal
ENERGY STAR Certified
Limited warranty - 3 years
AOC I960SRDA 19 Bundle deal on AOC I960SRDA 19" 1280x1024 6ms DVI HDMI DP IPS Monitor
£200.73
Diagonal Size: 19in
Response Time: 14ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
