AOC I960PRDA 19" 1280x1024 6ms DVI-D IPS Monitor
Quicklinx: B8NLWS00 Mfr#: I960PRDA
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 14ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£102.59 ex VAT
£123.10 inc VAT
This model targets business and home office users alike. Hidden behind its classically designed case is the latest LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
AOC Pro-line I960PRDA - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
14 ms (grey-to-grey)
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, pivot (rotation), swivel
40.92 cm x 43.22 cm x 21 cm
4.77 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, EAC
3-year warranty
Display Type
Diagonal Size
19"
Viewable Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
140 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
I-Menu, e-Saver technology, Eco Saving, Screen+, i-Care
4.77 kg
Audio
Speakers
VGA , DVI-D , Headphones
Mechanical
Tilt Angle
-5/+20
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x power cable
Power Supply
Internal
AC 230V (50/60 Hz)
16 Watt
Power Consumption Stand by
0.27 Watt
Power Consumption Sleep
0.21 Watt
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
AOC I960PRDA 19 Bundle deal on AOC I960PRDA 19" 1280x1024 6ms DVI-D IPS Monitor
£201.76
B8NL C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.83
B8NL C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.06
B8NL C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.60
B8NL C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
B8NL C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.42
Diagonal Size: 19in
Response Time: 14ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
