The 27-inch Full HD IPS panel of the I2790PQU offers great color accuracy and color gamut coverage. It combines a beautiful 3-sided frameless design with an ergonomic base and USB 3.0 connections.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Height adjustable stand
We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing. -
Flicker Free
AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort! -
IPS Panel
No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen. -
Frameless Design
3-Sides frameless design of the monitor lets the user focus on the vivid display, and onlookers will enjoy the sleek and modern look from every angle. -
Wide Colour Gamut
When you are enjoying photos, videos or games, we want your screen content to look as lifelike as possible. That is why this display comes with Wide Colour Gamut technology, which means that it is able to display a lot more colours than conventional monitors. This is achieved through a special hardware solution, not through mere software adjustments. The result: true-to-life images with fine details that become visible thanks to the broader colour palette.
- AOC I2790PQU - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, swivel, tilt
- Environmental Standards
- TCO Certified Displays 7, ENERGY STAR Qualified
- TUV GS, GOST, RoHS
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- HDCP, 100% sRGB colour gamut, Low Blue Light Mode, Flicker Free technology, 90% NTSC (CIE 1976) colour gamut, borderless
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- VGA (HD-15) , HDMI , DisplayPort , 4 x USB 3.0
Mechanical
- Tilt Angle
- -3.5/+19.5
- Swivel Angle
- 40
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- Cables Included
- 1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable
- Voltage Required
- AC 100/240 V (50/60 Hz)
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
