AOC I2790PQU 27" 1900x1080 4ms HDMI VGA DisplayPort LED Monitor
Quicklinx: D6WKWS00 Mfr#: i2790PQU/BT
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
11 in stock
£164.92 ex VAT
£197.90 inc VAT
The 27-inch Full HD IPS panel of the I2790PQU offers great color accuracy and color gamut coverage. It combines a beautiful 3-sided frameless design with an ergonomic base and USB 3.0 connections.
  • IPS panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favorite game - AOC wants your content to look excellent from whatever angle you are seeing it. That is why this display features an advanced IPS panel, which produces brilliant colors and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you - or your friends and coworkers sitting or standing next to you - are looking at the screen.
  • Flicker-Free
    AOC Flicker-Free technology utilizes a DC (direct current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimized, feel free to enjoy those long, intense gaming sessions in comfort!
  • Height-adjustable stand
    AOC cares about your wellbeing. This is why this monitor offers height adjustment possibilities, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • Integrated speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Wide Color Gamut
    When you are enjoying photos, videos or games, AOC wants your screen content to look as lifelike as possible. That is why this display features Wide Color Gamut technology, which means, that it is able to display a lot more colors. This is achieved through a special hardware solution. The result: true-to-life images with fine details, that become visible thanks to the broader color palette.
  • Frameless design
    3-sides frameless design of the monitor lets the user focus on the vivid display, and onlookers will enjoy the sleek and modern look from every angle.
AOC I2790PQU - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Environmental Standards
ENERGY STAR Qualified
TUV GS, GOST, RoHS
3-year warranty
Display Type
Energy Class
Class A+
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, 100% sRGB colour gamut, Low Blue Light Mode, Flicker Free technology, 90% NTSC (CIE 1976) colour gamut, borderless
Audio
Speakers
Output Power / Channel
2 Watt
VGA (HD-15) , HDMI , DisplayPort , 4 x USB 3.0
Mechanical
Tilt Angle
-3.5/+19.5
Swivel Angle
40
Height Adjustment
130 mm
VESA Mounting Interface
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable
TUV GS, GOST, RoHS
AC 100/240 V (50/60 Hz)
ENERGY STAR Certified
Limited warranty - 3 years
AOC I2790PQU 27 Bundle deal on AOC I2790PQU 27" 1900x1080 4ms HDMI VGA DisplayPort LED Monitor
£264.09
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 150 - 300
