AOC I2490PXQU/BT 23.8" 1920x1080 4ms HDMI VGA DisplayPort LED Monitor
Quicklinx: D6WJWS00 Mfr#: i2490PXQU/BT
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
38 in stock
£137.49 ex VAT
£164.98 inc VAT
The AOC I2490PXQU has an appealing look with 3-sided frameless design and a flexible, sturdy stand with multiple ergonomic options. Its 23.8-inch IPS panel delivers sharp and vivid images covering 90% of the NTSC and 100% of the sRGB color gamut. The I2490PXQU excels at color uniformity and color accuracy. In addition to its wide viewing angles of up to 178°, its ergonomic base supports -5° /25° tilt, -165°/165° swivel, 130 mm height adjustment and pivot (90°) capability, which guarantees working comfort in every setting. Its HDMI, VGA and DisplayPort inputs offer a variety of connection options. Users spending long hours in front of a monitor will be relieved with the Flicker-Free technology reducing flicker by regulating backlight, and the low blue light mode reducing the harmful short wavelength blue light. The energy-efficient I2490PXQU is also certified with ecolabels such as Energy Star, EPEAT and TCO.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Height adjustable stand
    We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • Flicker Free
    AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
  • IPS Panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen.
  • Frameless Design
    3-Sides frameless design of the monitor lets the user focus on the vivid display, and onlookers will enjoy the sleek and modern look from every angle.
  • Wide Colour Gamut
    When you are enjoying photos, videos or games, we want your screen content to look as lifelike as possible. That is why this display comes with Wide Colour Gamut technology, which means that it is able to display a lot more colours than conventional monitors. This is achieved through a special hardware solution, not through mere software adjustments. The result: true-to-life images with fine details that become visible thanks to the broader colour palette.
AOC I2490PXQU/BT - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Environmental Standards
TCO Certified Displays 8
3-year warranty
Display Type
Energy Class
Class A+
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Audio
Speakers
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Audio line-in
Mechanical
Tilt Angle
-3.5/+19.5
Swivel Angle
20
Height Adjustment
130 mm
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable
AC 100 - 240 V (50/60 Hz)
TCO Certified
Limited warranty - 3 years
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
