AOC I2490PXQU/BT 23.8" 1920x1080 4ms HDMI VGA DisplayPort LED Monitor
Quicklinx: D6WJWS00 Mfr#: i2490PXQU/BT
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
10 in stock
£127.31 ex VAT
£152.77 inc VAT
The AOC I2490PXQU has an appealing look with 3-sided frameless design and a flexible, sturdy stand with multiple ergonomic options. Its 23.8-inch IPS panel delivers sharp and vivid images covering 90% of the NTSC and 100% of the sRGB color gamut. The I2490PXQU excels at color uniformity and color accuracy. In addition to its wide viewing angles of up to 178°, its ergonomic base supports -5° /25° tilt, -165°/165° swivel, 130 mm height adjustment and pivot (90°) capability, which guarantees working comfort in every setting. Its HDMI, VGA and DisplayPort inputs offer a variety of connection options. Users spending long hours in front of a monitor will be relieved with the Flicker-Free technology reducing flicker by regulating backlight, and the low blue light mode reducing the harmful short wavelength blue light. The energy-efficient I2490PXQU is also certified with ecolabels such as Energy Star, EPEAT and TCO.
  • Integrated speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Heigt adjustable stand
    This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • Full HD resolution
    Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources.
  • IPS panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favorite game. That is why this display comes with an advanced IPS panel, which produces brilliant colors and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you - or your friends and co-workers sitting or standing next to you - are looking at the screen.
AOC I2490PXQU/BT - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Environmental Standards
TCO Certified Displays 8
3-year warranty
Display Type
Energy Class
Class A+
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Audio
Speakers
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Audio line-in
Mechanical
Tilt Angle
-3.5/+19.5
Swivel Angle
20
Height Adjustment
130 mm
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable
AC 100 - 240 V (50/60 Hz)
TCO Certified
Limited warranty - 3 years
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
