Enjoy brilliantly colored, vivid images on this large 60.4 cm (23.8") widescreen monitor. Boasting a high-grade IPS panel with Full HD resolution, the I2475PXQU delivers exceptionally wide viewing angles for multimedia and office applications. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, plus speakers as well as a USB hub integrated into the bezel, this energy-efficient display offers you a multitude of options. Benefit from full ergonomic flexibility with 130 mm height adjustment, tilt, swivel and pivot (= portrait mode rotation) functions. The I2475PXQU comes in a classy black texturised design and features eco-friendly LED-backlights. It fulfils demanding sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold. Let this stylish monitor impress you today!
- AOC I2475PXQU - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 200000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, DisplayPort, VGA
- Height, pivot (rotation), tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.444 cm x 48.9 cm x 21.291 cm
- 5.53 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, FCC, RoHS, EAC
- 3-year warranty
- Display Type
- Energy Class
- Class A
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, i-Menu, e-Saver technology, Flicker Free technology
- Black
- 55.444 cm x 48.9 cm x 21.291 cm - with stand
- 5.53 kg
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- VGA , HDMI , DVI , DisplayPort , 4 x USB 3.0
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 165
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Input Voltage
- Power Consumption (Typical)
- 14.8 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.2 Watt
- On / Off Switch
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
