AOC I2475PXQU 23.8" 1920x1080 4ms VGA DVI HDMI Monitor
Price Drop!
Clearance
Last Few Remaining
Price Drop
Quicklinx: CB89WS00 Mfr#: I2475PXQU
Enjoy brilliantly colored, vivid images on this large 60.4 cm (23.8") widescreen monitor. Boasting a high-grade IPS panel with Full HD resolution, the I2475PXQU delivers exceptionally wide viewing angles for multimedia and office applications. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, plus speakers as well as a USB hub integrated into the bezel, this energy-efficient display offers you a multitude of options. Benefit from full ergonomic flexibility with 130 mm height adjustment, tilt, swivel and pivot (= portrait mode rotation) functions. The I2475PXQU comes in a classy black texturised design and features eco-friendly LED-backlights. It fulfils demanding sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold. Let this stylish monitor impress you today!
AOC I2475PXQU - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 200000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort, VGA
Display Position Adjustments
Height, pivot (rotation), tilt
55.444 cm x 48.9 cm x 21.291 cm
5.53 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, EAC
3-year warranty
Display Type
Energy Class
Class A
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, i-Menu, e-Saver technology, Flicker Free technology
55.444 cm x 48.9 cm x 21.291 cm - with stand
5.53 kg
Audio
Speakers
Output Power / Channel
2 Watt
VGA , HDMI , DVI , DisplayPort , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+25
Swivel Angle
165
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
14.8 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
ENERGY STAR Certified
Limited warranty - 3 years
CB89 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.43
CB89 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.97
CB89 C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £25.08
CB89 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
CB89 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.69
CB89 C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.45
CB89 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.06
CB89 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.14
