This 21.5-inch display packs in a variety of features for a convenient and productive workspace. ADS-IPS panel technology provides extra-wide viewing angles of up to 178 degrees and the range of connectors (including USB) makes it ideal for multimedia setups. The height-adjustable ergonomic stand lets you tilt, swivel and pivot the screen to the preferred position.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
HDMI input
High Definition Multimedia Interface or HDMI is a global standard for digitally transmitting high-definition video and multichannel audio. This versatile single-cable solution allows you to easily connect your display to devices like computers, laptops, game consoles and media players. -
Adjustable Height
Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
- AOC Pro-line I2260PWHU - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.1 cm x 24.45 cm x 39.47 cm
- 5.35 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, FCC, TUV Bauart, EAC
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- HDCP, i-Menu, e-Saver technology, Screen+, i-Care
- Black
- 51.1 cm x 24.45 cm x 39.47 cm - with stand
- 5.35 kg
Audio
- Speakers
- DVI-D , HDMI , VGA , 4 x USB 2.0 , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x USB cable , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.4 Watt
- Power Consumption Sleep
- 0.2 Watt
- On / Off Switch
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
