AOC I2260PWHU 22" 1920x1080 5ms DVI-D HDMI IPS Monitor
Quicklinx: B8NNWS00 Mfr#: I2260PWHU
This 21.5-inch display packs in a variety of features for a convenient and productive workspace. ADS-IPS panel technology provides extra-wide viewing angles of up to 178 degrees and the range of connectors (including USB) makes it ideal for multimedia setups. The height-adjustable ergonomic stand lets you tilt, swivel and pivot the screen to the preferred position.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • HDMI input
    High Definition Multimedia Interface or HDMI is a global standard for digitally transmitting high-definition video and multichannel audio. This versatile single-cable solution allows you to easily connect your display to devices like computers, laptops, game consoles and media players.
  • Adjustable Height
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
AOC Pro-line I2260PWHU - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Voltage
51.1 cm x 24.45 cm x 39.47 cm
5.35 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, TUV Bauart, EAC
3-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Screen+, i-Care
51.1 cm x 24.45 cm x 39.47 cm - with stand
5.35 kg
Audio
Speakers
DVI-D , HDMI , VGA , 4 x USB 2.0 , Audio line-in
Mechanical
Tilt Angle
-5/+20
Height Adjustment
130 mm
VESA Mounting Interface
1 x VGA cable , 1 x DVI cable , 1 x USB cable , 1 x audio cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
0.2 Watt
On / Off Switch
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
B8NN C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
