The AOC G2778VQ is the RTS gamer's solution. Take in the full battlefield all at once on a 27" display in Full HD 1920 x 1080 resolution. FreeSync technology eliminates screen tearing and stuttering in real time by synchronizing the monitor's refresh rate with the GPU's frame rate. What more would you need? Flicker-Free technology reduces screen flicker and eye fatigue for the longer games to help you retain focus on uber micro. The display is VGA, HDMI and DisplayPort compatible. Built-in 2x 2W Speakers also help reduce desk clutter; external speakers not needed for quality sound.
1ms Response Time
A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting. -
FreeSync
Whatever your setup, achieve the highest framerate and smoothest display possible via AMD Free-Sync Technology. Whether you're dashing through explosions or screeching around rain slicked bends, wave goodbye to screen tearing and lag – and leave your opponents in your smoothly rendered dust. -
75Hz Refresh Rate
Get the upper edge! With a 75 Hz refresh rate, the display panel draws 75 frames each second. 75 Hz refresh rate is 25% faster than what is offered on most entry level displays at 60 Hz, while still being affordable and delivering those extra frames gamers need to beat their opponents. -
DisplayPort Connection
The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications. -
Display Port
- AOC Gaming G2778VQ - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 49 kWh
- Power Consumption (On mode)
- 34 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, red
- 64.03 cm x 29.91 cm x 47.07 cm
- 5.98 kg
- DDC-2B, CCC, FCC, RoHS, ISO 9241-307, cTUVus, EPA, DDC-2B/CI
- Display Type
- Energy Class
- Class B
- 49 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- HDCP, Flicker Free technology
- Black, red
- 5.98 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI , VGA , DisplayPort
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Input Voltage
- 34 W
- Power Consumption (Typical)
- 32 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- OS Required
- Microsoft Windows 7, Windows 8
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
