AOC G2778VQ LED monitor 27"1920 x 1080 Full HD (1080p
Quicklinx: D325WS00 Mfr#: G2778VQ
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£139.97 ex VAT
£167.96 inc VAT
The AOC G2778VQ is the RTS gamer's solution. Take in the full battlefield all at once on a 27" display in Full HD 1920 x 1080 resolution. FreeSync technology eliminates screen tearing and stuttering in real time by synchronizing the monitor's refresh rate with the GPU's frame rate. What more would you need? Flicker-Free technology reduces screen flicker and eye fatigue for the longer games to help you retain focus on uber micro. The display is VGA, HDMI and DisplayPort compatible. Built-in 2x 2W Speakers also help reduce desk clutter; external speakers not needed for quality sound.
  • 1ms Response Time
    A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • FreeSync
    Whatever your setup, achieve the highest framerate and smoothest display possible via AMD Free-Sync Technology. Whether you're dashing through explosions or screeching around rain slicked bends, wave goodbye to screen tearing and lag – and leave your opponents in your smoothly rendered dust.
  • 75Hz Refresh Rate
    Get the upper edge! With a 75 Hz refresh rate, the display panel draws 75 frames each second. 75 Hz refresh rate is 25% faster than what is offered on most entry level displays at 60 Hz, while still being affordable and delivering those extra frames gamers need to beat their opponents.
  • DisplayPort Connection
    The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
  • Display Port
AOC G2778VQ - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
49 kWh
Power Consumption (On mode)
34 W
Adaptive-Sync Technology
AMD FreeSync
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Black, red
64.03 cm x 29.91 cm x 47.07 cm
5.98 kg
Environmental Standards
TCO Certified Displays 7
DDC-2B, CCC, FCC, RoHS, ISO 9241-307, cTUVus, EPA, DDC-2B/CI
Display Type
Energy Class
Class B
49 kWh
34 W
Diagonal Size
27"
AMD FreeSync
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Flicker Free technology
Black, red
5.98 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , VGA , DisplayPort
Mechanical
VESA Mounting Interface
100 x 100 mm
32 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Microsoft Windows 7, Windows 8
TCO Certified
10 - 85% (non-condensing)
Diagonal Size: 27in
Response Time: 1ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
