Designed for serious gamers, the 24-inch AOC G2460PF display delivers an extra smooth playing experience with AMD FreeSync. Combined with an AMD Radeon graphics card and AMD Catalyst driver, FreeSync seamlessly synchronizes the monitor and GPU refresh rates to eliminate tearing, stuttering and input lag. Ultra fast 1ms response time and impressive 144Hz refresh rate diminish distractions like blurring and ghosting that can mean the difference between victory and defeat. Whether you're racing around the track or stalking enemies in a first-person shooter, the Full HD resolution delivers sharp, true-to-life imagery.
Freesync Premium
Enjoy the best quality visuals even in fast paced games. The AMD FreeSync Premium Technology ensures that the GPU's and monitor's refresh rates are synchronised, which provides a fluid, tear free gaming experience at highest performance. The AMD FreeSync Premium features a refresh rate of minimum 120Hz, decreasing blur and sharpening the picture for a more life-like experience. The LFC feature eliminates the risk of stutter in case the frame rate drops below the refresh rate. -
1ms Response Time
A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting. -
144 Hz Refresh Rate
Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 144Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory. -
Height adjustable stand
We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
- AOC Gaming G2460PF - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 144 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.54 cm x 24.458 cm x 39.36 cm
- 6.54 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, FCC, RoHS, REACH, EuP, EAC
- Bundled Services
- Re-Spawned 3 Year Advance Replacement and Zero Dead Pixel Guarantee / 1 Year One-Time Accident Damage Exchange
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Vertical Refresh Rate
- 50 - 146 Hz
- Horizontal Refresh Rate
- 30 - 160 kHz
- Video Bandwidth
- 330 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 170
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- HDCP, i-Menu, e-Saver technology, Screen+, i-Care, Flicker Free technology, Zero power switch
- Black
- 56.54 cm x 24.458 cm x 39.36 cm - with stand
- 6.54 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI-D (dual link) , HDMI , DisplayPort , Headphones , 4 x USB 2.0
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 330
- VESA Mounting Interface
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
- Input Voltage
- Power Consumption SDR (On mode)
- 21 kWh/1000h
- Power Consumption (Typical)
- 22.7 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
Sustainability Information
- ENERGY STAR Certified
- Bundled Services
