AOC G2460PF 24" 1920x1080 1ms VGA DVI HDMI Gaming Monitor
Quicklinx: C29NWS00 Mfr#: G2460PF
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£189.97 ex VAT
£227.96 inc VAT
Designed for serious gamers, the 24-inch AOC G2460PF display delivers an extra smooth playing experience with AMD FreeSync. Combined with an AMD Radeon graphics card and AMD Catalyst driver, FreeSync seamlessly synchronizes the monitor and GPU refresh rates to eliminate tearing, stuttering and input lag. Ultra fast 1ms response time and impressive 144Hz refresh rate diminish distractions like blurring and ghosting that can mean the difference between victory and defeat. Whether you're racing around the track or stalking enemies in a first-person shooter, the Full HD resolution delivers sharp, true-to-life imagery.
  • Superior gaming control
    Gamers can dial-in shadow levels in the OSD menu to increase contrast for better dark areas on the screen definition without affecting the rest of the screen.
  • Easy to connect
    AOC gaming monitors are very easy to connect. The G2460PF has several external input ports, but also has dedicated USB 2.0 and device-charging ports, making it easy for you to charge your mobile device or transfer data while focused on your gaming session.
  • Fully adjustable stand
    The G2460PF's fully adjustable stand allows convenient adjustment of the screen's height and angle. Match the screen's position to your chair position, height, and line of sight for a comfortable playing experience.
AOC AGON G2460PF - LCD monitor - Full HD (1080p) - 24"
LCD monitor - 24"
Energy Class
Class B
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Pivot (rotation), swivel, tilt
56.54 cm x 24.458 cm x 39.36 cm
6.54 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, FCC, RoHS, REACH, EuP, TCO Displays 6.0, EAC
Bundled Services
Re-Spawned 3 Year Advance Replacement and Zero Dead Pixel Guarantee / 1 Year One-Time Accident Damage Exchange
Display Type
LCD monitor / TFT active matrix
Energy Class
Class B
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
50 - 146 Hz
Horizontal Refresh Rate
30 - 160 kHz
Video Bandwidth
330 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Screen+, i-Care, Flicker Free technology, Zero power switch
56.54 cm x 24.458 cm x 39.36 cm - with stand
6.54 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (dual link) , HDMI , DisplayPort , Headphones , 4 x USB 2.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
330
VESA Mounting Interface
Stand
1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
22.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
ENERGY STAR Certified
Bundled Services
AOC G2460PF 24 Bundle deal on AOC G2460PF 24" 1920x1080 1ms VGA DVI HDMI Gaming Monitor
£289.14
C29N C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.57
C29N C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.28
C29N C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £25.40
C29N C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
C29N C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.66
C29N C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.34
C29N C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.35
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 150 - 300
