AOC Featured U2879VF 28" LED Monitor
Quicklinx: D2NKWS00 Mfr#: U2879VF
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£216.66 ex VAT
£259.99 inc VAT
The visually impressive U2879VF combines an expansive 28? screen size with 4K Ultra HD resolution for super-sharp, highly detailed images. The 10-bit Deep Color panel can display over a billion hues simultaneously, for superb realism and natural shading. A blisteringly fast screen response time shows fast-moving action without blurring, while AMD FreeSync technology matches the graphics signal to the screen timing to eliminate stuttering and tearing.
Ultra-high dynamic contrast intelligently adjusts brightness to reveal darker image details with greater depth and clarity. A full range of input connectors, including fast DisplayPort and dual-link DVI technologies, ensure compatibility with every device. The audio jack allows convenient attachment of headphones or desktop speakers.
  • Flicker Free
    AOC Flicker Free technology utilizes a DC backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimized, feel free to enjoy those long, intense gaming sessions in comfort!
  • PiP
    With multiple inputs like DisplayPort, HDMI and Dual-Link DVI, this monitor enables you to multiply your viewing with Picture-in-Picture and Picture-by-Picture capabilities.
  • Fast response time
    Fast response time means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of ghosting.
AOC U2879VF - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 30 Hz, HDMI2: 60 Hz, DVI: 30 Hz)
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
1.073 billion colours (8-bit)
Input Connectors
HDMI (MHL), VGA, DVI-D, DisplayPort
Display Position Adjustments
Tilt
Black & silver
65.93 cm x 4.87 cm x 37.94 cm
4 kg
Environmental Standards
TCO Certified Displays 7
Plug and Play, BSMI, DDC-2B, CCC, FCC, RoHS, WEEE, cTUVus, EPA, DDC-2B/CI, RCM, ISO9241-307
3-year warranty
Display Type
Energy Class
Class B
64 kWh
44 W
Diagonal Size
28"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Pixel Per Inch
157
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 140 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
Picture in picture, picture by picture, power off timer, HDCP, i-Menu, e-Saver technology, Screen+, Flicker Free technology
Black & silver
4 kg
VGA , MHL / HDMI , DVI-D (dual link) (HDCP) , DisplayPort , Headphones
Mechanical
Tilt
Tilt Angle
-3.5/+23.5
Security lock slot (cable lock sold separately), LED indicator
Security Slot Type
Kensington security slot
49 Watt
Power Consumption Stand by
0.32 Watt
Power Consumption (Off Mode)
0.23 Watt
On / Off Switch
No
Shipping Width
73.2 cm
Shipping Depth
15.9 cm
Shipping Height
54.3 cm
Shipping Weight
5.26 kg
TCO Certified
Limited warranty - parts and labour - 3 years
10 - 85% (non-condensing)
AOC Featured U2879VF 28 Bundle deal on AOC Featured U2879VF 28" LED Monitor
£315.83
Diagonal Size: 28in
Response Time: 1ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 150 - 300
