AOC E719SDA 17" 1280x1024 5ms VGA DVI-D Black Monitor with Speakers
Quicklinx: 96G7WS00 Mfr#: E719SDA
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
Hurry, only 1 left in stock!
£90.67 ex VAT
£108.80 inc VAT
The e719Sda offers a 17" diagonal screen in picture format 5:4. The e719Sda delivers a high typical contrast of 1000:1 and a fast pixel response time of 5 ms, this monitor is great for standard office applications such as text editing, web browsing or e-mail correspondence. With 250 cd/m², the e719Sda delivers enough luminance to also be used in environments with bright ambient light. The integrated loudspeakers allow listening to play system sounds or other audio content. Via D-Sub or DVI-D, contents can be displayed in SuperXGA resolution. The energy-efficient LED-backlights allows the e719Sda to fulfil demanding sustainability certificates such as EPEAT Silver and Energy Star 6.0. AOC equips the monitor with intelligent software to further reduce power consumption.
AOC e719Sda - LED monitor - 17"
LED-backlit LCD monitor - 17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Black, silver
37.16 cm x 5.89 cm x 32.67 cm
3.86 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0, EPA 6.0
3-year warranty
Display Type
Diagonal Size
17"
Viewable Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Eco-Mode, i-Menu, e-Saver technology
Black, silver
3.86 kg
Audio
Speakers - integrated
Output Power / Channel
1 Watt
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+18
VESA Mounting Interface
100 x 100 mm
ENERGY STAR Certified
Limited warranty - 3 years
AOC E719SDA 17 Bundle deal on AOC E719SDA 17" 1280x1024 5ms VGA DVI-D Black Monitor with Speakers
£190.43
96G7 C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.00
96G7 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.26
96G7 C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.98
96G7 C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £10.77
96G7 C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
96G7 C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.66
96G7 C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £39.16
96G7 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.69
96G7 C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £52.24
Diagonal Size: 17in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 50 - 100
