The e719Sda offers a 17" diagonal screen in picture format 5:4. The e719Sda delivers a high typical contrast of 1000:1 and a fast pixel response time of 5 ms, this monitor is great for standard office applications such as text editing, web browsing or e-mail correspondence. With 250 cd/m², the e719Sda delivers enough luminance to also be used in environments with bright ambient light. The integrated loudspeakers allow listening to play system sounds or other audio content. Via D-Sub or DVI-D, contents can be displayed in SuperXGA resolution. The energy-efficient LED-backlights allows the e719Sda to fulfil demanding sustainability certificates such as EPEAT Silver and Energy Star 6.0. AOC equips the monitor with intelligent software to further reduce power consumption.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Kensington Lock
Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it. -
Vesa Mount
AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option. -
LED-backlight
AOC's monitors use LED backlights with white LEDs to illuminate the display panel (TN, IPS or VA). Compared to old backlights using CCFL, LED backlights have much lower energy consumption and more dimming control over the brightness, and contribute to the thinness of the display.
- AOC e719Sda - LED monitor - 17"
- LED-backlit LCD monitor - 17"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 75 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Black, silver
- 37.16 cm x 5.89 cm x 32.67 cm
- 3.86 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- EPA 6.0
- 3-year warranty
- Display Type
- Diagonal Size
- 17"
- Viewable Size
- 17"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Eco-Mode, i-Menu, e-Saver technology
- Black, silver
- 3.86 kg
Audio
- Speakers - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+18
- VESA Mounting Interface
- 100 x 100 mm
- EPA 6.0
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 1m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £7.32 |
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £7.95 |
