For work or home, this monitor offers excellent performance with 16.7 million colors and 5ms response time. Smart features like Eco Mode and e-Saver help you effortlessly reduce power consumption.
This large format Full HD monitor boasts a diagonal of stunning 68.6 cm (27"). Delivering a response time of 5 ms only and a static contrast of 1000:1, the e2770She is well-equipped for both your multimedia and office applications. With connectors for analog signals via D-Sub and digitally via its two HDMI ports, the model also features a 3.5 mm jack. Simply plug in your external audio device and enjoy movies, music or video calls with your friends. The e2770She is equipped with eco-friendly LED-backlights and intelligent software to further reduce energy consumption.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
HDMI input
High Definition Multimedia Interface or HDMI is a global standard for digitally transmitting high-definition video and multichannel audio. This versatile single-cable solution allows you to easily connect your display to devices like computers, laptops, game consoles and media players.
- AOC e2770She - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 64.24 cm x 24.19 cm x 44.93 cm
- 4.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, GOST, FCC, RoHS, ISO 9241-307, EuP, NRTL
- 3-year warranty
- Display Type
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 99 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Eco-Mode, i-Menu, e-Saver technology, Screen+
- 64.24 cm x 24.19 cm x 44.93 cm - with stand
- 4.8 kg
- 2 x HDMI , VGA , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Backlight Life
- 50,000 hours
- Input Voltage
- Power Consumption (Typical)
- 31 Watt
- Power Consumption Stand by
- 0.37 Watt
- 0.15 Watt
- Shipping Width
- 73 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 50 cm
- Shipping Weight
- 6.8 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
