AOC e2770She 27" 1920x1080 5ms VGA HDMI LED Monitor
Quicklinx: 96GWWS00 Mfr#: e2770She
For work or home, this monitor offers excellent performance with 16.7 million colors and 5ms response time. Smart features like Eco Mode and e-Saver help you effortlessly reduce power consumption.
This large format Full HD monitor boasts a diagonal of stunning 68.6 cm (27"). Delivering a response time of 5 ms only and a static contrast of 1000:1, the e2770She is well-equipped for both your multimedia and office applications. With connectors for analog signals via D-Sub and digitally via its two HDMI ports, the model also features a 3.5 mm jack. Simply plug in your external audio device and enjoy movies, music or video calls with your friends. The e2770She is equipped with eco-friendly LED-backlights and intelligent software to further reduce energy consumption.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • HDMI input
    High Definition Multimedia Interface or HDMI is a global standard for digitally transmitting high-definition video and multichannel audio. This versatile single-cable solution allows you to easily connect your display to devices like computers, laptops, game consoles and media players.
AOC e2770She - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Voltage
64.24 cm x 24.19 cm x 44.93 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, GOST, FCC, RoHS, ISO 9241-307, EuP, NRTL
3-year warranty
Display Type
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 99 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Eco-Mode, i-Menu, e-Saver technology, Screen+
64.24 cm x 24.19 cm x 44.93 cm - with stand
4.8 kg
2 x HDMI , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Backlight Life
50,000 hours
Input Voltage
Power Consumption (Typical)
31 Watt
Power Consumption Stand by
0.37 Watt
Power Consumption (Off Mode)
0.15 Watt
Shipping Width
73 cm
Shipping Depth
14.5 cm
Shipping Height
50 cm
Shipping Weight
6.8 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
96GW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
