Your basket is empty
AOC e2770She 27" 1920x1080 5ms VGA HDMI LED Monitor
Quicklinx: 96GWWS00 Mfr#: e2770She
For work or home, this monitor offers excellent performance with 16.7 million colors and 5ms response time. Smart features like Eco Mode and e-Saver help you effortlessly reduce power consumption.
This large format Full HD monitor boasts a diagonal of stunning 68.6 cm (27"). Delivering a response time of 5 ms only and a static contrast of 1000:1, the e2770She is well-equipped for both your multimedia and office applications. With connectors for analog signals via D-Sub and digitally via its two HDMI ports, the model also features a 3.5 mm jack. Simply plug in your external audio device and enjoy movies, music or video calls with your friends. The e2770She is equipped with eco-friendly LED-backlights and intelligent software to further reduce energy consumption.
AOC e2770She - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
31 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
4.8 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, GOST, FCC, RoHS, ISO 9241-307, EuP, NRTL
3 years warranty
Display Type
Energy Class
Class B
45 kWh
31 W
Diagonal Size
27"
Viewable Size
27"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Eco-Mode, i-Menu, e-Saver technology, Screen+
4.8 kg
2 x HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
On / Off Switch
No
ENERGY STAR Certified
Limited warranty - 3 years
96GW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
96GW C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
96GW C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
96GW C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
96GW C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
96GW C2G Pro HDMI to VGA Converter In Stock £46.35
