AOC E2770SH 27" 1920 x 1080 1ms VGA DVI HDMI LED Monitor
Quicklinx: CQRSWS00 Mfr#: E2770SH
The 27-inch AOC E2770SH display was designed with speed in mind. The ultra-fast response time makes it perfect for passionate gamers, as well as anyone who uses graphics, animation and film editing applications. Simply connect your AV sources via the model's D-Sub, DVI or HDMI ports and enjoy flawless picture quality. The built-in speaks offer rich, clear sound for movies, music or video calls.
  • 1ms Response Time
    A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Vesa Mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option.
AOC Value E2770SH - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Speaker
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Voltage
64.24 cm x 24.19 cm x 44.93 cm
4.8 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
3-year warranty
Display Type
Energy Class
Class B
Diagonal Size
27"
Built-in Devices
Speaker
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Screen+
4.8 kg
Audio
Speakers
DVI (HD-15) , VGA , HDMI , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
VESA interface support
Stand
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
Input Voltage
Power Consumption (Typical)
31 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
