AOC E2475SWQE 24" 1920x1080 1ms VGA HDMI DisplayPort LED Monitor
Quicklinx: FVJQWS00 Mfr#: E2475SWQE
The E2475SWQE offers great image quality at 1920 x 1080 Full HD resolution, while providing features and connectivity that benefit you. Slim in design with extra narrow bezel while offering vibrant images with 20M: 1 contrast ratio, and rapid 1 ms response time. The E2475SWQE also has all the connectivity you need for high quality digital video and audio.
  • Full HD resolution for vibrant and ?lear image
    AOC'S E2475SWQE has a slim design that is prefect for saving desktop space, while giving you the optimum viewable image screen with 16:9 aspect ratio. The LED backlit monitor runs a maximum 1920 x 1080 Full HD resolution.
  • Fast 1m response time for smooth graphics rendering
    A 1ms response time means you get to enjoy fast-moving actions without worrying about images mearing or ghosting that occurs with slow response time. In other words, you get to experience a lag-free gaming with that desired competitive edge. Enjoy fast-moving action and dramatic transitions without the annoying effects of ghosting, thanks to the smooth rendering.
  • Connectivity and features you need in a monitor
    E2475SWQE features VGA, HDMI, and Display Port connections, audio line-in and line-out. HDMI connection carries both high-definition picture and sound in one easy cable.
AOC E2475SWQE - 75 Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
20 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
20000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 110/240 V (50/60 Hz)
55.88 cm x 19.85 cm x 42.46 cm
3.25 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC, RoHS, WEEE, cTUVus
3-year warranty
Display Type
Energy Class
Class A
34 kWh
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
I-Menu, e-Saver technology
3.25 kg
HDMI , DisplayPort , Headphone input , VGA (HD-15)
Mechanical
Tilt
Tilt Angle
-3.5/+21.5
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
20 W
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
Drivers & Utilities, I-Menu, e-Saver
Shipping Width
63 cm
Shipping Depth
12.8 cm
Shipping Height
41.8 cm
Shipping Weight
4.64 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 85% (non-condensing)
