This ergonomically adjustable and energy efficient business monitor boasts DisplayPort and HDMI connectors for high-speed digital input, as well as stereo speakers.
Height adjustable stand
We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing. -
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Kensington Lock
Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
- AOC Pro-line E2475PWJ - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Class
- Class E
- Power Consumption (On mode)
- 17 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 2 ms
- Input Connectors
- HDMI, DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 2 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 170
- Backlight Technology
- WLED
- I-Menu, e-Saver technology, Flicker Free technology
Audio
- Speakers
- DVI , HDMI , VGA
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 330
- Height Adjustment
- 130 mm
- Wall mountable
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- Input Voltage
- AC 120/230 V
- 17 W
- Power Consumption SDR (On mode)
- 17 kWh/1000h
- Power Consumption (Typical)
- 18.03 Watt
- Power Consumption Stand by
- 0.33 Watt
- 0.25 Watt
- On / Off Switch
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.78 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £227.08 |
StarTech.com Dual Monitor Stand | In Stock | £91.06 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
