AOC E2470SWHE 23.6" 1920x10805ms VGA DVI HDMI LED Monitor
Quicklinx: 96GTWS00 Mfr#: e2470Swhe
Diagonal Size: 23.6in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: [N/A]
Interfaces: HDMI, VGA (HD-15)
12 in stock
£92.00 ex VAT
£110.40 inc VAT
The E2470SWHE comes in a timelessly classic black design equipped with a high-quality 59.9 cm (23.6") Full HD panel. Delivering superb picture quality thanks to a high typical contrast of 1000:1 in combination with a 250 cd/m² luminosity and a pixel response time of 5 ms only, the E2470SWHE is perfectly equipped for both office and entertainment applications. Simply connect your AV sources via the model's D-Sub or two HDMI ports and enjoy flawless picture quality. Despite its large screen, this 23.6" monitor bargain consumes a mere 26 watts in standard mode. Furthermore, AOC fits out all of its monitors with clever software and presets to further save energy and enhance the overall user experience. Let the e2470Swhe stun you today.
AOC E2470SWHE - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
55.14 cm x 7.82 cm x 39.69 cm
3.58 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
TCO Displays 6.0, EPA 6.0
3-year warranty
Display Type
Energy Class
Class B
37 kWh
25 W
Diagonal Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Horizontal Viewing Angle
178
Vertical Viewing Angle
160
Backlight Technology
WLED
Eco-Mode, i-Menu, e-Saver technology
3.58 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
26 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
AOC E2470SWHE 23.6 Bundle deal on AOC E2470SWHE 23.6" 1920x10805ms VGA DVI HDMI LED Monitor
£191.17
96GT C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
96GT C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.80
96GT C2G 5m Select High Speed HDMI with Ethernet In Stock £22.72
96GT C2G 10m Select High Speed HDMI with Ethernet In Stock £43.63
96GT C2G 15m Select High Speed HDMI with Ethernet In Stock £59.09
Response Time: 5ms
Speakers: [N/A]
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 50 - 100
