AOC e2460Sh 24" 1920x1080 1ms HDMI DVI-D VGA Black Monitor with Speakers
FULL HD RESOLUTION!
Quicklinx: 9T4TWS00 Mfr#: E2460SH
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
21 in stock
£89.12 ex VAT
£106.94 inc VAT
The 24-inch AOC e2460Sh display was designed with speed in mind. The ultra-fast GTG response time makes it perfect for passionate gamers, as well as anyone who uses graphics, animation and film editing applications. Full HD resolution reveals the finest details while the impressive dynamic contrast delivers sharp imagery with deep, true blacks. The built-in speakers offer rich, clear sound for movies, music or video calls. The stand easily tilts the screen to a comfortable position, or use the VESA mount to hang it on the wall. VGA, DVI and HDMI connectors let you hook up multiple computers, devices and peripherals.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • 1ms Response Time
    A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Vesa Mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option.
AOC Value e2460Sh - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
56.54 cm x 21.93 cm x 41.16 cm
4.27 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, TUV GS, RoHS, ISO9241-307, Ukrain Safety
3-year warranty
Display Type
Energy Class
Class A
32 kWh
22 W
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
165 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
56.54 cm x 21.93 cm x 41.16 cm - with stand
4.27 kg
Audio
Speakers - integrated
Output Power / Channel
2 Watt
VGA , HDMI , DVI-D , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable , 1 x HDMI cable
Power Supply
Internal
22 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
Included Software
Drivers & Utilities
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
9T4T C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.80
9T4T C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £10.91
9T4T C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.55
9T4T C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
9T4T C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.48
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 50 - 100
