AOC E2460PQ 24" 1920x1080 2ms VGA DVI DisplayPort LED Monitor
Quicklinx: B3LMWS00 Mfr#: e2460Pq/BK
This 24-inch display combines impressive performance with added features to make your workday more productive. Full HD resolution offers fantastic imagery and vibrant colors, whether you’re editing images or updating a website. High contrast ratios and quick 2ms response time ensure sharp, lag-free viewing for your most demanding applications. Built-in 2-watt speakers and a headphone jack mean you’ll never miss a word of your presentation or video call. And VGA, DVI-D and DisplayPort connectors make it easy to hook up your computer and external devices. While you focus on business, the ergonomic stand lets you work comfortably – adjust the height, swivel and tilt to the ideal position, or pivot the screen from landscape to portrait mode.
AOC Professional E2460PQ - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
56.54 cm x 24.35 cm x 39.36 cm
6.38 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, RoHS, ISO 9241-307, EuP
3-year warranty
Display Type
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
165 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode, e-Saver technology
56.54 cm x 24.35 cm x 39.36 cm - with stand
6.38 kg
Audio
Speakers
VGA , DVI-D (HDCP) , DisplayPort
Mechanical
Tilt Angle
-5/+22
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Power Supply
Internal
22 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years
B3LM C2G HDMI to DisplayPort Adapter Converter In Stock £37.26
B3LM C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.52
B3LM C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.58
B3LM C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
B3LM C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.23
B3LM C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.14
B3LM C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.83
