This LED-backlit monitor delivers a solid performance for standard office and home applications. Coming in a classy black texturised finish, the tiltable widescreen model is equipped with a fast-reacting TN panel, boasting a 5 ms pixel response time for crisp, blur-free images. Intelligent programs such as Screen+ and i-Menu enhance the user experience and help to save energy. The eco-friendly series 70 fulfils demanding sustainability certificates such as ENERGY STAR 6.0 and EPEAT Silver and is prepared for both VESA wall mount and Kensington security devices.
Full HD Resolution
Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources. -
Kensington Lock
Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it. -
Vesa Mount
AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option. -
LED-backlight
AOC's monitors use LED backlights with white LEDs to illuminate the display panel (TN, IPS or VA). Compared to old backlights using CCFL, LED backlights have much lower energy consumption and more dimming control over the brightness, and contribute to the thinness of the display.
- AOC e2270Swdn - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 700:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Black
- 50.337 cm x 4.8 cm x 31.11 cm
- 2.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
- 3-year warranty
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- WLED
- I-Menu, e-Saver technology, Screen+
- Black
- 2.7 kg
- DVI-D , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.2 m , 1 x DVI cable - 1.5 m
- Backlight Life
- 50,000 hours
- Voltage Required
- AC 100/240 V (50/60 Hz)
- 18.19 Watt
- Power Consumption Stand by
- 0.2 Watt
- 0.2 Watt
- Shipping Width
- 56 cm
- Shipping Depth
- 11 cm
- Shipping Height
- 39.5 cm
- Shipping Weight
- 3.45 kg
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Limited warranty - 3 years
Accessories (7)
StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount | In Stock | £64.78 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £121.66 |
StarTech.com Articulating Monitor Arm | In Stock | £104.51 |
StarTech.com Dual Monitor Stand | In Stock | £80.65 |
StarTech.com Cubicle Monitor Hanger | In Stock | £45.79 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £75.93 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £84.59 |
Other bundles (1)
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £7.95 |
