AOC E2270SWDN TN 21.5"  1920 x 1080  VGA & DVI
Quicklinx: BWTJWS00 Mfr#: E2270SWDN
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: DVI, VGA (HD-15)
Hurry, only 2 left in stock!
£73.63 ex VAT
£88.35 inc VAT
Express delivery Order within the next 5 hours for delivery tomorrow
This LED-backlit monitor delivers a solid performance for standard office and home applications. Coming in a classy black texturised finish, the tiltable widescreen model is equipped with a fast-reacting TN panel, boasting a 5 ms pixel response time for crisp, blur-free images. Intelligent programs such as Screen+ and i-Menu enhance the user experience and help to save energy. The eco-friendly series 70 fulfils demanding sustainability certificates such as ENERGY STAR 6.0 and EPEAT Silver and is prepared for both VESA wall mount and Kensington security devices.
  • LED-backlight
    AOC's monitors use LED backlights with white LEDs to illuminate the display panel. Compared to old backlights using CCFL, LED backlights have much lower energy consumption and more dimming control over the brightness, and contribute to the thinness of the display.
  • VESA mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3rd party mounts and stands thanks to the VESA mount option.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organization, or wherever you carry it.
  • Full HD resolution
    Want to watch a Blu-ray movie in full quality, enjoy games in high resolution or read crisp text in office applications? Thanks to its Full HD resolution of 1920 x 1080 pixels, this monitor lets you do just that. Whatever you are viewing, with Full HD it will be displayed in rich detail without requiring a high-end graphics card or consuming a lot of your system's resources.
AOC e2270Swdn - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
700:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
50.337 cm x 4.8 cm x 31.11 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
3-year warranty
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
I-Menu, e-Saver technology, Screen+
2.7 kg
DVI-D , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.2 m , 1 x DVI cable - 1.5 m
Backlight Life
50000 hours
AC 100/240 V (50/60 Hz)
18.19 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption (Off Mode)
0.2 Watt
Shipping Width
56 cm
Shipping Depth
11 cm
Shipping Height
39.5 cm
Shipping Weight
3.45 kg
ENERGY STAR Certified
ENERGY STAR Version
6.0
Limited warranty - 3 years
AOC E2270SWDN TN 21.5 Bundle deal on AOC E2270SWDN TN 21.5" 1920 x 1080 VGA & DVI
£173.39
Accessories (7)
BWTJ StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.11
BWTJ StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
BWTJ StarTech.com Articulating Monitor Arm In Stock £103.82
BWTJ StarTech.com Dual Monitor Stand In Stock £69.36
BWTJ StarTech.com Cubicle Monitor Hanger In Stock £45.98
BWTJ StarTech.com TV/Monitor Arm - Wallmount In Stock £59.78
BWTJ StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Other bundles (8)
BWTJ C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.26
BWTJ C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.98
BWTJ C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £10.77
BWTJ C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BWTJ C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.66
BWTJ C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £39.16
BWTJ C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.69
BWTJ C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £52.24
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 50 - 100
