AOC E2260PWDA 21.5" Widescreen 1920x1080 5MS VGA DVI Speakers LED Monitor
Quicklinx: 8GYHWS00 Mfr#: E2260PWDA
This model targets business and home office users alike. Hidden behind its classically designed case is the LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • Adjustable Height
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
AOC Professional e2260Pwda - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Voltage
AC 90 - 240 V (50/60 Hz)
51.1 cm x 24.45 cm x 39.47 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-1, DDC-2B, FCC, DDC/CI, RoHS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode, e-Saver technology
Audio
Speakers
VGA , DVI-D (HDCP) , Headphones
Mechanical
Tilt Angle
-5/+15
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Input Voltage
Power Consumption (Typical)
18 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.3 Watt
Included Software
Drivers & Utilities, Screen+, I-Menu
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
8GYH C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
