The e2260Pq is a true statement regarding both performance and design. Thanks to its LED backlights, this 55.9 cm (22") model is not only highly energy-efficient, but also has an elegant slim appearance. Coming in the practical 16:10 format with Wide XGA+ resolution, the e2260Pq offers extra desktop space in height compared to standard widescreen models - just perfect for lengthy tables, long documents and busy e-mail clients. With a pixel response time of 2 ms only, a high typical contrast of 1000:1 and a 250 cd/m2 luminance, the e2260Pq stands for super-smooth imaging. Users also benefit from integrated speakers and the ergonomic flexibility, allowing to tilt and swivel the monitor, adjust its height and even to use it in portrait mode (pivot). Next to a D-Sub input, the e2260Pq also provides digital DVI-D and DisplayPort connectors.
Adjustable Height
Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort. -
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Height adjustable stand
We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing. -
Kensington Lock
Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it. -
Vesa Mount
AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option.
- AOC e2260Pq - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050 at 60 Hz
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Black
- 50.78 cm 24.46 cm
- 5.65 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Plug and Play, TUV GS, RoHS, ISO 9241-307, EuP
- 3-year warranty
- Display Type
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 146 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
- Black
- 50.78 cm 24.46 cm - with stand
- 5.65 kg
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- DVI-D , VGA , DisplayPort
Mechanical
- Tilt Angle
- -5/+22
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x DVI cable
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 19 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 10m DisplayPort Cable with Latches M/M – Black | In Stock | £22.18 |
C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black | In Stock | £15.34 |
C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £19.63 |
C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black | In Stock | £15.05 |
