AOC E2260PQ/BK 22" 1680x1050 2ms DVI-D DP LED Monitor
Quicklinx: B8NPWS00 Mfr#: E2260PQ/BK
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 2ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
48 in stock
£143.34 ex VAT
£172.00 inc VAT
The e2260Pq is a true statement regarding both performance and design. Thanks to its LED backlights, this 55.9 cm (22") model is not only highly energy-efficient, but also has an elegant slim appearance. Coming in the practical 16:10 format with Wide XGA+ resolution, the e2260Pq offers extra desktop space in height compared to standard widescreen models - just perfect for lengthy tables, long documents and busy e-mail clients. With a pixel response time of 2 ms only, a high typical contrast of 1000:1 and a 250 cd/m2 luminance, the e2260Pq stands for super-smooth imaging. Users also benefit from integrated speakers and the ergonomic flexibility, allowing to tilt and swivel the monitor, adjust its height and even to use it in portrait mode (pivot). Next to a D-Sub input, the e2260Pq also provides digital DVI-D and DisplayPort connectors.
AOC e2260Pq - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
50.78 cm 24.46 cm
5.65 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, RoHS, ISO 9241-307, EuP, TCO Displays 6.0
3-year warranty
Display Type
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
146 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
50.78 cm 24.46 cm - with stand
5.65 kg
Audio
Speakers
Output Power / Channel
2 Watt
DVI-D , VGA , DisplayPort
Mechanical
Tilt Angle
-5/+22
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable , 1 x DVI cable
Power Supply
Internal
19 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - 3 years
AOC E2260PQ/BK 22 Bundle deal on AOC E2260PQ/BK 22" 1680x1050 2ms DVI-D DP LED Monitor
£243.10
B8NP C2G HDMI to DisplayPort Adapter Converter In Stock £38.59
B8NP C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.34
B8NP C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £7.86
B8NP C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
B8NP C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £24.05
B8NP C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.69
B8NP C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.37
B8NP C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.37
Diagonal Size: 22in
Response Time: 2ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
