AOC E2260PDA 22" Widescreen 1680x1050 5MS DVI VGA Speakers LED Monitor
Quicklinx: 8GYGWS00 Mfr#: E2260PDA
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
40 in stock
£131.02 ex VAT
£157.22 inc VAT
This model targets business and home office users alike. Hidden behind its classically designed case is the LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
AOC e2260Pda - LED monitor - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
50.78 cm x 52.13 cm x 24.46 cm
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
DDC-1, DDC-2B, DDC/CI
3-year warranty
Display Type
Diagonal Size
22"
Viewable Size
22"
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Video Bandwidth
146 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
DVI-D (HDCP) , VGA
Mechanical
Tilt Angle
-5/+20
Swivel Angle
178
Rotation Angle
94
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
15.5 Watt
Power Consumption Stand by / Sleep
0.4 Watt
0.4 Watt
Power Consumption Sleep
0.34 Watt
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
8GYG C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.83
8GYG C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.06
8GYG C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.60
8GYG C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
8GYG C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.42
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
