AOC E2260PDA 22" Widescreen 1680x1050 5MS DVI VGA Speakers LED Monitor
Quicklinx: 8GYGWS00 Mfr#: E2260PDA
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
34 in stock
£132.49 ex VAT
£158.98 inc VAT
This model targets business and home office users alike. Hidden behind its classically designed case is the LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • Adjustable Height
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Height adjustable stand
    We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
  • Vesa Mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option.
AOC e2260Pda - LED monitor - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
50.78 cm x 52.13 cm x 24.46 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
DDC-1, DDC-2B, DDC/CI
3-year warranty
Display Type
Diagonal Size
22"
Viewable Size
22"
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Video Bandwidth
146 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
DVI-D (HDCP) , VGA
Mechanical
Tilt Angle
-5/+20
Swivel Angle
178
Rotation Angle
94
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
15.5 Watt
Power Consumption Stand by / Sleep
0.4 Watt
0.4 Watt
Power Consumption Sleep
0.34 Watt
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
8GYG C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.88
8GYG C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £10.91
8GYG C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.74
8GYG C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
8GYG C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.57
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
