AOC E1759FWU 17" 600x900 10ms USB LED Monitor
Quicklinx: B8NZWS00 Mfr#: E1759FWU
E1759FWU is the perfect USB-powered portable monitor accessory for laptop and computer. The widescreen monitor receives both power and signal via a single USB cable for plug-and-play connection; it does not require a power cord or VGA cable, and comes with a removable base for maximum flexibility.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • USB monitor
    Discover the freedom and flexibility of AOC's myConnect USB monitors. A single USB cable connects your laptop to the directly to the display, completely eliminating the need for extra media cables and a power supply. The USB cable transfers data to the screen, plus acts as an energy-efficient power source. For work or play, these monitors offer optimal portability. Besides ultra-easy connectivity, the innovative stand offers you a variety of viewing options.
AOC E1759FWU - LED monitor - 17.3"
LED-backlit LCD monitor - 17.3"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Brightness
200 cd/m²
Contrast Ratio
650:1
Response Time
10 ms
Input Connectors
USB
Display Position Adjustments
Pivot (rotation)
Piano black
3-year warranty
Display Type
Diagonal Size
17.3"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Brightness
200 cd/m²
Contrast Ratio
650:1
Response Time
10 ms
Backlight Technology
WLED
FlexStand, USB bus powered, Slim Design
Piano black
USB
Mechanical
Pivot (rotation)
Wall mountable, portrait / landscape mode
Included Software
Drivers & Utilities
Limited warranty - parts and labour - 3 years
