AOC AOC Pro-line E2475SWJ - LCD monitor - 23.6" - 1920 x 1080
Quicklinx: D3NKWS00 Mfr#: E2475SWJ
This all around top performer offers the ideal solution for a variety of business settings. With optimized brightness and high contrast ratios, the 23.6-inch E2475SWJ delivers sharp, vivid imagery in Full HD (1920 x 1080) resolution. Fast 2ms response time handles videos, animations and the most demanding software applications with ease. Integrated VGA, DVI and HDMI connectors make it easy to connect a computer, laptop and a range of other devices. The built-in speakers and headphone jack offer extra convenience for online calls and more. And to keep you working in comfort, Flicker Free technology helps reduce eye fatigue.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
  • Vesa Mount
    AOC's Ergo Base stands bring versatility, sturdiness and ease of use in one package. But do you still want to use your wall mount or multi-monitor setup using desk mounts? VESA mounts bring you the uppermost flexibility. Upside-down, in pivot mode, on top of each other, attach your monitor wherever you want using 3 rd party mounts and stands thanks to the VESA mount option.
AOC Pro-line E2475SWJ - LCD monitor - Full HD (1080p) - 23.6"
LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
55.88 cm x 19.85 cm x 42.46 cm
3.25 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TCO '06, TUV Bauart, EAC
3 years warranty
Display Type
LCD monitor / TFT active matrix
Energy Class
Class A
35 kWh
23 W
Diagonal Size
23.6"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
HDCP, i-Menu, e-Saver technology, Flicker Free technology
55.88 cm x 19.85 cm x 42.46 cm - with stand
3.25 kg
Audio
Speakers
Output Power / Channel
2 Watt
DVI , HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+23.5
Flat Panel Mount Interface
100 x 100 mm
Wall mountable, kensington security slot
Stand
DVI / VGA / Power
20 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
ENERGY STAR Certified
Limited warranty - 3 years
