AOC AOC I1659FWUX  16" (15.6" viewable) LED Portable Monitor
Quicklinx: DLGLWS00 Mfr#: I1659FWUX
Diagonal Size: 16in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: USB
17 in stock
£113.67 ex VAT
£136.40 inc VAT
16" Class USB Powered IPS Monitor
16" Class USB Powered IPS Monitor, Sleek Design and Fast USB 3.0 Connection
* Beautiful IPS Display
* 15.6" Screen with 1920 x 1080 Full HD Resolution
* Ultra-slim and Lightweight for Portability
* USB 3.0 for USB-powered for Plug-and-play Connection
* Foldable Flexi-stand and Auto-pivot for Landscape and Portrait Mode
* Built-in Display Link Technology for Multiple USB Monitors Connection
  • Beautiful IPS panel
    The improved USB monitor from AOC is sleeker in design and faster with its USB 3.0 connection. USB 3.0 achieves high transfer rates with its total of six wires in the data cable, and delivers high quality images. Design with a piano-black glossy finish, this USB monitor has a 15.6" diagonally viewable image. The beautiful IPS panel of the I1659FWUX offers a 700:1 contrast ratio and a crisp 1920 x 1080 Full HD Resolution at 60Hz.
  • Auto-pivot for landscape or portrait mode
    The I1659FWUX USB Monitor has a foldable flexi-stand for viewing in landscape or portrait mode. Landscape mode is ideal for presentations and Excel sheets, while the Portrait mode conveniently gives you an easy vertical view of your instant messaging program, or sidebars such as search results. This monitor has the unique auto-pivot feature that automatically adjusts the image according to the display's orientation, so you will never have to change settings as you switch between landscape and portrait mode.
  • Ultra lightweight and slim portability
    It's ultra-lightweight and slim for great portability, making it perfect for business presentations, the frequent traveler, photo frame applications, and dual monitor setups on-the-go. The I1659FWUX USB monitor is the solution for the frequent traveler who needs to pack multiple displays, as it easily fits into a backpack or the carry case that comes with the USB monitor.
AOC I1659FWUX - LED monitor - Full HD (1080p) - 16"
LED-backlit LCD monitor - 16"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
220 cd/m²
Contrast Ratio
700:1
Response Time
5 ms
Input Connectors
USB
Display Position Adjustments
Pivot (rotation), tilt
Piano black
37.19 cm x 3.55 cm x 23.27 cm
1.2 kg
Environmental Standards
ENERGY STAR Qualified
FCC, RoHS, cTUVus
3-year warranty
Display Type
Diagonal Size
16"
Viewable Size
15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
220 cd/m²
Contrast Ratio
700:1
Response Time
5 ms
Horizontal Viewing Angle
160
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
English, French, Spanish
Glossy, foldable stand
Piano black
37.19 cm x 3.55 cm x 23.27 cm - with stand
1.2 kg
USB 3.0
Mechanical
Tilt Angle
15-30
VESA Mounting Interface
75 x 75 mm
Carrying case
1 x SuperSpeed USB cable
FCC, RoHS, cTUVus
8 Watt
Power Consumption Stand by
0.5 Watt
Shipping Width
44.2 cm
Shipping Depth
8.5 cm
Shipping Height
29.5 cm
Shipping Weight
1.76 kg
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 16in
Response Time: 5ms
Interfaces: USB
Brand: AOC
Price Range Ex VAT: 100 - 150
