AOC AOC E2275PWJ 21.5 INCH LED 2MS VGA DVI HDMI SPEAKERS HA
Quicklinx: D5TLWS00 Mfr#: E2275PWJ
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 2ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£97.57 ex VAT
£117.08 inc VAT
This all around top performer is the ideal solution for a variety of business settings. The 21.5-inch E2275PWJ delivers rich, vivid imagery in Full HD (1920x1080) resolution, plus offers fast 2ms response time to handle your most demanding applications. Integrated VGA, DVI and HDMI connectors make it easy to hook up a computer, laptop and a range of other devices. The built-in speakers and headphone jack provide extra convenience for online calls and more. To ensure you work in comfort, the ergonomic stand easily adjusts to a variety of positions (including pivot mode) and Flicker Free technology helps reduce eye fatigue.
AOC Pro-line E2275PWJ - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 200000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
50.4 cm x 21.29 cm x 46.88 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TCO '06, TUV Bauart, EAC
3-year warranty
Display Type
Energy Class
Class B
32 kWh
22 W
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
WLED
HDCP, i-Menu, e-Saver technology, Flicker Free technology
50.4 cm x 21.29 cm x 46.88 cm - with stand
4.8 kg
Audio
Speakers
Output Power / Channel
2 Watt
DVI , HDMI , VGA
Mechanical
Tilt Angle
-5/+25
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
Stand
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Security Slot Type
Kensington security slot
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
ENERGY STAR Certified
Limited warranty - 3 years
AOC AOC E2275PWJ 21.5 INCH LED 2MS VGA DVI HDMI SPEAKERS HA Bundle deal on AOC AOC E2275PWJ 21.5 INCH LED 2MS VGA DVI HDMI SPEAKERS HA
£197.33
Response Time: 2ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 50 - 100
