AOC AGON AG251FG 24.5" 1920x1080 Monitor
Quicklinx: DQSXWS00 Mfr#: AG251FG
Diagonal Size: 24.5in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£386.89 ex VAT
£464.26 inc VAT
Screen tearing, motion blur and ghosting effects are some annoying problems competitive gamers can face during extensive gaming sessions. With a refresh rate of 240 Hz and a fast response time, the premium gaming monitor AOC AGON AG251FG puts an end to these issues once and for all. Instead, competitive gamers are able to enjoy smooth and highly response gameplay and graphics.
  • 240Hz Refresh rate
    By far the fastest refresh rate on the market, 240Hz completely unleashes top end GPUs, bringing unprecedented fluidity to the picture on your screen. With every detail brought sharply into focus and every movement shown with crystal clarity, feel your reactions become one with the action and elevate your game.
  • 1ms Response Time
    A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • G-Sync
    G-Sync ensures that the GPU's and monitor's refresh rates are synchronised, which provides a smooth, tear free gaming experience with no input lag. You can enjoy the best quality image and outstanding gameplay even in high paced games.
  • Shadow Control
    Bring the battle out of the shadows with Shadow Control! Brighten dark areas or sink them back into blackness on the fly, without affecting the rest of the display.
  • Lowblue Light
    AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowbue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage.
AOC AGON AG251FG - LED monitor - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1920 x 1080 at 240 Hz
Pixel Pitch
0.2802 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Black, red
56.665 cm x 21.825 cm x 54.521 cm
6.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, DICOM Part 14, REACH, TUV Bauart, EuP, EAC
3-year warranty
Display Type
Energy Class
Class B
47 kWh
32 W
Diagonal Size
24.5"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2802 mm
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
48 - 240 Hz
Horizontal Refresh Rate
30 - 275 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Flicker Free technology
Black, red
6.5 kg
Audio
Speakers
Output Power / Channel
2 Watt
DisplayPort , HDMI , 4 x USB 3.0 upstream (USB)
Mechanical
Tilt Angle
-3.5/+21.5
Swivel Angle
40
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, Flicker-free technology, HDCP Compliant
1 x HDMI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
AC 100 - 240 V (50/60 Hz)
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years
AOC AGON AG251FG 24.5 Bundle deal on AOC AGON AG251FG 24.5" 1920x1080 Monitor
£486.06
Response Time: 1ms
Interfaces: HDMI
Brand: AOC
Price Range Ex VAT: 300 - 500
