AOC 34" Gaming Curved LED 3440 x 1440 WQHD @ 144 Hz
Quicklinx: G124WS00 Mfr#: CU34G2X/BK
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort
£267.63 ex VAT
£321.15 inc VAT
ULTRA-WIDE
The term Ultrawide refers to the screen aspect ratio of a monitor. With more space at your disposal, your field of view gets greatly increased.
144HZ REFRESH RATE
Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 144Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory.
MINIMAL BEZEL DISTRACTION FOR THE ULTIMATE BATTLE STATION
Expand your view with multiple monitor set-up. The narrow border and frameless design offer the minimal bezel distraction for the ultimate battle station.
HEIGHT ADJUSTABLE STAND
Raise or lower the screen to suit each individual’s height and seating preferences. The easy-to-adjust stand ensures hours of comfort.
LOW INPUT LAG
Unleash your reflexes by switching to the AOC Low Input Lag mode. Forget graphical frills: this mode rewires the monitor in favour of raw response time, giving the ultimate edge in hair trigger stand offs.
6 GAMES MODE
Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customise your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy.
AOC GAME COLOR AND SHADOW CONTROL
Bring the battle out of the shadows with AOC Shadow Control and AOC Game Color! Adjust grey levels for better picture detail and brighten dark areas or sink them back into blackness on the fly, without affecting the rest of the display.
  • 1MS MPRT
    A pixel response time of 1ms means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • 144 Hz
  • FreeSync
    The AMD FreeSync Technology ensures that the GPU's and monitor's refresh rates are synchronised, which provides a smooth, tear free gaming experience. You will appreciate the low input lag if you're looking for the best quality visuals in fast paced games.
AOC Gaming CU34G2X/BK - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class F
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 144 Hz
Pixel Pitch
0.2316 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
119% sRGB, 88% Adobe RGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
3H Hard Coating
Voltage
DisplayPort 1.2
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
34"
Curved Screen
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2316 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
1 ms (MPRT)
Vertical Refresh Rate
48 - 146 Hz
Horizontal Refresh Rate
30 - 160 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
WLED
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
Flicker Free technology, frameless bezel design
2 x HDMI , DisplayPort , Headphones , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
3.5/21.5
Swivel Angle
30
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
DisplayPort 1.2
Input Voltage
31.4 kWh/1000h
Power Consumption HDR (On mode)
65 kWh/1000h
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Diagonal Size: 34in
Response Time: 1ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: AOC
