AOC 34" Gaming Curved LED 3440 x 1440 WQHD @ 100 Hz
Quicklinx: G123WS00 Mfr#: CU34G2/BK
The CU34G2 provides an incredible gaming experience with its WQHD resolution. Enjoy your games on this large 34" curved monitor to make them look even more detailed and captivating. Thanks to its incredibly low 1ms response time, AMD FreeSync and 100 Hz refresh rate it is also suited for fast-paced games.
  • Ultra-wide
    The term Ultrawide refers to the screen aspect ratio of a monitor. With more space at your disposal, your field of view gets greatly increased.
  • 100Hz Refresh Rate
    Equip yourself with twice the frame rate of other monitors and say goodbye to image stuttering and blurry motion. With a 100Hz refresh rate every frame is rendered sharply and in smooth succession, so you can line up your shots accurately and appreciate high speed races in all their glory.
  • 1ms MPRT - Moving Picture Response Time
    MPRT is an acronym for moving picture response time. MPRT technology disables and enables your monitor backlight during picture changes. Through the reduced time a frame is shown on the monitor, "ghosting" and "blurring" effects are reduced, resulting in a smoother, more "fluid" feeling gaming experience.
  • 1500R Curved
    Curved design wraps around you putting you at the centre of the action and provides an immersive gaming experience.
  • Minimal bezel distraction for the ultimate battle station
    Expand your view with multiple monitor set-up. The narrow border and frameless design offer the minimal bezel distraction for the ultimate battle station.
  • Height adjustable Stand
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of comfort.
  • Low Input Lag
    Unleash your reflexes by switching to the AOC Low Input Lag mode. Forget graphical frills: this mode rewires the monitor in favour of raw response time, giving the ultimate edge in hair trigger stand offs.
  • 6 Games Mode
    Tailor your display to the game with a click of a button. Switch settings between in-built presets for FPS, racing, or RTS games, or customise your own ideal conditions and save them. The AOC Settings KeyPad makes switching profiles or adjusting features quick and easy.
  • AOC Game Color and Shadow control
    Bring the battle out of the shadows with AOC Shadow Control and AOC Game Color! Adjust grey levels for better picture detail and brighten dark areas or sink them back into blackness on the fly, without affecting the rest of the display.
  • AOC G-menu
    AOC G-Menu is a free tool that you can install on your PC to have complete customization paired with maximum convenience.
  • Adaptive sync
    Adaptive Sync aligns your monitor's vertical refresh rate with the frame rate delivered by your GPU, making your gameplay and casual gaming experience even more fluid by eliminating stuttering, tearing and judder. This feature is also useful when enjoying videos and other visual media, for a smoother entertainment.
AOC Gaming CU34G2/BK - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class G
Power Consumption (On mode)
38.9 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync Premium
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 100 Hz
Pixel Pitch
0.2316 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
124% sRGB, 92% Adobe RGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
3H Hard Coating
Voltage
80.834 cm x 13.237 cm x 39.816 cm
8 kg
FCC, RoHS, TUV Bauart, EAC, ISO 9241-307 Class 1
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
34"
Curved Screen
Yes (1500R)
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2316 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
1 ms (MPRT)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
WLED
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
Flicker Free technology, USB 3.0 Fast Charge
80.834 cm x 13.237 cm x 39.816 cm - with stand
8 kg
2 x HDMI , DisplayPort 1.2 , Headphones , 4 x USB 3.0
Mechanical
Tilt Angle
3.5/21.5
Swivel Angle
30
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Input Voltage
38.9 W
38.9 kWh/1000h
Power Consumption HDR (On mode)
40.5 kWh/1000h
Power Consumption (Typical)
55 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - weight: 6.5 kg
Shipping Width
90.3 cm
Shipping Depth
28 cm
Shipping Height
54.8 cm
Shipping Weight
9.47 kg
