AOC 24P1 23.8" 1920x1080 VGA DVI HDMI DisplayPort USB IPS LED Monitor
Quicklinx: F4P3WS00 Mfr#: 24P1
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, VGA (HD-15), DVI, HDMI
32 In Stock
£102.69 ex VAT
£123.22 inc VAT
Sleek and elegant thanks to 3-sides borderless design, achieved thanks to the IPS panel in Full HD (1920x1080px) resolution. Includes full range of display inputs (VGA, DVI, HDMI, DisplayPort), built-in speakers and improved ergonomic stand with 150 mm height adjustment.
  • Display Port
    DisplayPort offers ultra-fast digital audio and video transmission without quality loss or input lag. Quickly and easily connect a range of devices to your screen, including your computer, laptop, media player, game console and more. It's perfect for professionals as well as the most demanding home users.
  • Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Height adjustable Stand
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of comfort.
  • IPS Panel
    IPS panel ensures an excellent viewing experience with lifelike yet brilliant and accurate colours. Colours look consistent no matter from which angle you look at the display
  • Low Blue Light
    AOC Lowblue Light protects you from harmful blue light which, during long sessions, has been shown to cause eye strain, headaches, and sleeping disorders. Our Lowblue Light feature reduces the harmful wavelengths emitted without sacrificing colour composition, setting the experience free from the worry of eye damage.
  • Flicker Free
    AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort!
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge.
AOC 24P1 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
18 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort, VGA
Display Position Adjustments
Voltage
53.91 cm x 20.25 cm x 51.89 cm
4.6 kg
Environmental Standards
TCO Certified Displays 8
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
Borderless
53.91 cm x 20.25 cm x 51.89 cm - with stand
4.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , DVI , Headphones , 4 x USB 3.0
Mechanical
Tilt Angle
-2.5/+92.5
Swivel Angle
350
Height Adjustment
150 mm
Stand
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x audio cable - 1.5 m
MTBF
50,000 hour(s)
Input Voltage
18 W
18 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Width: 75.2 cm - depth: 5.9 cm - height: 40.8 cm - weight: 6.55 kg
Sustainability Information
TCO Certified
Limited warranty - 3 years
Response Time: 5ms
Interfaces: VGA (HD-15)
Interfaces: DVI
Interfaces: HDMI
Brand: AOC
