AOC 23.6" LED TFT (E2460SD2) 1920 x 1080 1ms VGA DVI
Quicklinx: CRM4WS00 Mfr#: E2460SD2
The 24-inch E2460SD2 display features Full HD resolution for detailed imagery and a fast 1 ms response time that makes it suitable even for games or movies. Standard VGA and DVI-D connectors make this monitor ideal for a variety of office and home users.
  • 1 ms response time
    A pixel response time of 1ms GTG means speed without the smear for an enhanced experience. Fast-moving action and dramatic transitions will be rendered smoothly without the effects of ghosting.
  • LED-backlight
    AOC's monitors use LED backlights with white LEDs to illuminate the display panel (TN, IPS or VA). Compared to old backlights using CCFL, LED backlights have much lower energy consumption and more dimming control over the brightness, and contribute to the thinness of the display
AOC e2460Sd2 - Value - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
1 ms
Input Connectors
DVI-D, VGA
Voltage
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, EAC
3-year warranty
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
1 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
LED backlight
HDCP, i-Menu, e-Saver technology, Screen+, i-Care
VGA , DVI-D
Mechanical
VESA Mounting Interface
Wall mountable
1 x VGA cable , 1 x DVI cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.29 Watt
Dimensions & Weight Details
With stand - width: 56.54 cm - depth: 21.93 cm - height: 40.305 cm - weight: 4.64 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
