Product
AOC 23.6" LED TFT (E2460SD2) 1920 x 1080 1ms VGA DVI
Quicklinx: CRM4WS00 Mfr#: E2460SD2
The 24-inch E2460SD2 display features Full HD resolution for detailed imagery and fast 1ms response time to keep up with your most demanding applications. Standard VGA and DVI-D connectors and the VESA mount make this monitor ideal for a variety of workspaces.
This model targets business and home office users alike. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
A pixel response time of 1 ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of ghosting.
AOC Value E2460SD2 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
1 ms
Input Connectors
DVI-D, VGA
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TCO '06, EAC
3-year warranty
Display Type
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
1 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
LED backlight
HDCP, i-Menu, e-Saver technology, Screen+, i-Care
VGA , DVI-D
Mechanical
Flat Panel Mount Interface
Wall mountable
1 x VGA cable , 1 x DVI cable
Power Supply
Internal
28 Watt
Power Consumption Stand by
0.29 Watt
Dimensions & Weight Details
With stand - width: 56.54 cm - depth: 21.93 cm - height: 40.305 cm - weight: 4.64 kg
ENERGY STAR Certified
Limited warranty - 3 years
